I'm trying to create a Sub-Assembly that has point codes that will follow whatever i pick for the point code above with a prefix like the Stock C3D Lane Super Elevation Sub Assembly AOR. So as an example if I pick Crown for P1 point then I would like the P9 Point to automatically become Datum_Crown. (see included screen shots)
Solved by Jowennl. Go to Solution.
Hi @Anonymous ,
Please see attached SamplePrefix.zip (You need to unzip to get the PKT). See animated gif and guides below.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
