2013 version. The structures used to show in the profile for my storm system and now they don't. I've checked all I can think of. Layers are on and not frozen, profile says it should be showing the structure and there are no overrides. Styles show the correct things. I've regened, closed and opened the drawing, and unchecked the boxes for the structures I want shown in the profile, and then reapplied them. Pipes look like they are touching, then I add the structures and they move apart like the structure is there, but it's just blank space. I've also tried clicking the structures in the plan view and using add parts to profile and still nothing. The space is there where the structure outline should be but there is no structure. I've tried clicking in the space to see if the structure is there but just not outlined and still get nothing.
Solved by kchudzinski. Go to Solution.
Solved by jmayo-EE. Go to Solution.
@Anonymous wrote:profile says it should be showing the structure and there are no overrides. Styles show the correct things. I've regened, closed and opened the drawing, and unchecked the boxes for the structures I want shown in the profile, and then reapplied them.
On the Display tab of the structure style are you switching the "View Direction" to Profile when verifying visibility?
If you apply an alternate style will a structure display?
Is _AeccSetNetworkCatalog set to the proper folder within your environment and is the "Structure catalog" set to the one you'd typically use? Caption shown is for 2012 but default path is same but 2013.
That's not cool. I remember the disappearing structures being a common problem in the 2007 version, but I haven't seen it since. I hope that they stay this time.
Just want to add, I had the same problem today when I came across this post looking for answer.
Make sure your alignment runs to the center of your structure.
This was the error in my case, I had my alignement ending 1ft inside a 96" structure and spent most the morning trying to figure out why the connected 96" structure wasn't showing up in my profile. Extended my alignment and viola, my structure appeared in my profile.
What is the insert elevation of the structures?
Joe Bouza
I also had problems with structures not shown in profile views. I had to swap part to another structure and then back again. The structure then appears in the profile view. I am using Civil 3D 2016.
I have encountered the same problem. This is what solved the issue. Make sure that the surface reference is also in the working file if the pipe network is data referenced.
In my case, the alignment is not the issue. The two structures with a problem of showing up are at 5+00 and 8+00 nowhere close to the end of the alignment. Any suggestions are welcome.
This trick saved me this morning, as i was only off by .01' if that, and moving the alignment solved the issue.
Thanks!
