Civil 3D Forum
corridor object viewer and it's 0 elevation shadow
3 REPLIES 3
RobertEVs
163 Views, 3 Replies
I have often wondered if there is a way to get rid of the ghost corridor model portion that finds its way to the bottom of the object viewer? As long as my corridor model has an elevation of about 10' then all is well but here in Colorado, we are typically designing between 5,280 and 12,000 feet (3,657 meters for everyone not in the US) which means corridor object viewer is not so much fun in orbit mode.
Labels (1)
3 REPLIES 3
VincentSheehan
in reply to: RobertEVs
Have you tried turning off the layers in the Corridor Style?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
RobertEVs
in reply to: VincentSheehan
That worked. TY. When I OBJV all I have to do is select the SE-TOP corner of the viewcube and the pivot gets reset. Glad I'm finally to get an answer to this. I do have to wonder if all this does is hide that base part of the corridor model in the viewer what's its purpose in the first place? I still see the corridor just up at its elevation?
Thanks again.
tcorey
If you edit the Corridor Style, you can set those layers on in plan view and off in model view.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
