Is there a way to have a streight leader line for the dragged state? When I drag my point labels out and have them at 45 degrees, I want the leader line to point directly to the text.
Solved by doni49. Go to Solution.
OK, that is a step in the right direction. I have my text rotated to 45 degrees but they are still alligned verticle if you know what I mean.
Wish I could make my dragged state look like it did in LDT. I inserted an image.
Like So? See the attached dwg.
Don Ireland
Engineering Design Technician
Getting closer, see image. Almost what I want but not quite. Someone out there must have done this already after all these years of C3D!
Yeah, that is close to what I have so far but I would like the leader line to line up with the center piece of text. I know this is picky but the powers to be here in the office want everything to look just like LDT.
See the updated dwg file attached. I changed it so that the ELEVATION is anchored at the feature. Now it's simply a matter of playing with the x & y offsets (for the Point Elevation on the Layout tab) until you get it the way you like.
Don Ireland
I'm pleased to hear that you got it resolved. Thanks for letting us know. Have a great day!
Don Ireland
