- Mute
- Permalink
- Report
Hello all,
I am working on a SSA model for a site that has two proposed storage ponds. When I first created the model, I connected the storage nodes to the pond outlet structures (loaded from the Civil 3D pipe network) with a direct link. This resulted in one of the ponds having 0.00 cfs outflow, and the other had the error "ERROR 134 : Node XXX has more than one DIRECT outlet link or DESIGN pump."
To mitigate this, I removed the outlet structures/junctions and connected the storage node directly to the pipe that is downstream from the outlet structure. Now my model will run, but the storage nodes don't actually store any runoff. The only scenario where (flow out of the pond) < (flow into the pond) is when it overflows.
The screenshots below show how one of my storage nodes is set up, as well as the associate storage curve. I have also tried changing the ponded area to match the area listed in the storage curve, but this results in no flow into the basin.
Thanks for any advice that you may have!
