Hello, I was hoping to get some ideas on how other people would have fulfilled a recent request...
A client wanted to compare a near vertical concrete wall that was poured incorrectly vs design. I setup a robot and gave it a rough scan every 0.2m, brought the point data into Excel and created a delta distance off design for every point along with chainage and elevation from top of wall for each point. Paired with a plan view of the wall showing chainage and point nodes on the wall.
The problem is it's a massive table and not easy to visualize. I would have much prefered to make a volume surface using as-built vs design and used elevation banding to show deviation. Which would have been great if it were a horizontal surface like the floor. But c3d doesn't handle vertical surface as well.
What would you have done?
