Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Stop crossing pipe from same network being labelled in profile
4 REPLIES 4
m_kingdon
321 Views, 4 Replies
Hi all,
I have a rather complex scheme with a stormwater network that is crossing over itself. I need to add these crossing pipes onto my profiles to show clearance, but is it possible to stop these crossing pipes interfering with the band labels in the profile?
I assume the answer is no and to manually delete the labels.  I don’t wish to split my network.
Bad
Good
Mike Kingdon
Civil 3D Zealot
4 REPLIES 4
m_kingdon
in reply to: m_kingdon
A solution I have found is to duplicate the profile view, have one profile view showing the normal spanning pipe with regular labels etc, have the second profile view only showing the crossing pipe, then move the profiles views on top of each other.  It is a bit crude but it will do for now.  I didn’t want to draw any pipes manually in case the design is updated later and I forget that the pipe I added is hand drawn and not dynamic.  Bad data is potentially more dangerous than no data.
Copy of profile showing crossing pipe.  I left the surfaces on as well to ensure profiles views are perfectly aligned.  If there is an alignment issue the surfaces will not match and will be easier to spot.
Mike Kingdon
Civil 3D Zealot
MMcCall402
Nicely done, and it all stays dynamically linked.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
cwr-pae
I agree with @MMcCall402 . Please mark it as solved by you.
MichaelH13
In short, no. But you have found a work around.
If they were in separate networks, then you could, as you tell the band what network to source pipe data from. But apart from turning off label visibility, you cannot select which pipes within a network the band will pull the data from.
Rail Community
