SSA Output in Excel displays only one inlet and outlet node number for all links and for any given link
the same number is displayed for the inlet and outlet nodes.
There are 64 links in the file, and the only node number that is displayed is 64.
Can something be done within the SSA number to display the correct inlet and outlet node number for each link?
![anmahmoud_1-1689206356307.png anmahmoud_1-1689206356307.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1239766i5149943031D97B18/image-size/medium?v=v2&px=400)
The pdf report does display the correct node numbers:
![anmahmoud_2-1689206511489.png anmahmoud_2-1689206511489.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1239768iED4EF2004655ABAC/image-size/medium?v=v2&px=400)
