Civil 3D Forum
Part Builder - AutoLayout Data not working??
1 REPLY 1
Nik-D
210 Views, 1 Reply
Hi all
I am trying to create a custom pipe cross section. I have created geometry and added all constraints and dimensions however....
1. The AutoLayout Data does not become active until I save close and reopen the part
2. When I right click on the Layout Data and click select placement point, it says invalid selection whenever I select a point
3. Whenever the Autolayout Data does become active it seems to have preselected the coordinates of (15,15,??)
4. If I rebuild the geometry so that the insertion point is (15,15), when I use the pipe in Civil 3D it shows in plan but not in 3D in the object viewer.
TIA
Labels (2)
1 REPLY 1
Nik-D
in reply to: Nik-D
Update:
When calling the function Select Placement point from the Layout Data,
it calls the function COLLAYOUTDATAPLACEMENT on the command line. This prompts you to select a point which in my case seems to always be invalid.
However, there is a command COLLAYOUTDATAINSERTION which allows you to select a point of your choice as opposed to some point object. So you can set the insertion of the 2D geometry to a known set of coordinates in your drawing and use this command to select that set of coordinates.
Can anyone confirm this behaviour in other versions of 2020? or is there something wrong with my Part Builder?
Rail Community
