Civil 3D Forum
Spot eleveation text rotation / alignment
7 REPLIES 7
Message 1 of 8
s.johnstonJ2BZF
1688 Views, 7 Replies
Does anyone have a step by step guide on how to rotate / align spot elevation text?
I’ve tried to rotate it, but I can’t seem to get the text flipped to be the same as my road chainge - see attached image
Scott
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: s.johnstonJ2BZF
0. In the label settings you can set a default angle, by view, by object.
1. Grab the label but do grip it
2. Hover over the blue box
3 select rotate labe , marker or both.
4. Tip: list the rotation angle put on clipboard , select similar your labels>>properties >> paste the angle
Joe Bouza
Message 3 of 8
s.johnstonJ2BZF
in reply to: Joe-Bouza
I've tried the method you suggested but I still can't get it to work. Once I rotate the label text past a certain angle the text automatically flips - which I don't want it to do.
any ideas on how override this? Or have I missed something?
many thanks
scott
Message 4 of 8
Go to the label style and look for plan readability, turn it off
Message 5 of 8
Message 6 of 8
rl_jackson
I'm not so sure I'd turn it off. Id definitely change the angle that it's at. I believe it defaults at like 110 and I set mine around 92 just my take one it. It s really whatever works best for you. I set mine and generally never have any issues.
Rick Jackson
Survey CAD Technician VI
Message 7 of 8
Joe-Bouza
Yours doesn't do this?
Your screencast, Rotae surface label, is ready for viewing.
https://autode.sk/2HCz9sv
Joe Bouza
Message 8 of 8
s.johnstonJ2BZF
I've got it Joe - I switched off plan readability and the labels rotated without the text flipping.
many thanks
scott
Rail Community
