I've modeled a pavement overlay job using OverlayMillAndLevel2, where the new pavement is 225mm higher than existing. This looks like it's worked well, and no need to mess about with vertical profiles.
I now need to tie-in at either end vertically. So transition down from 225mm to zero, longitudinally over 45m.
Is there any assembly that will do this? Or any ideas how to do it?
Any help is much appreciated.
Cheers,
Paul
Solved by Jowennl. Go to Solution.
Hi @Anonymous,
You can use numerictransformation.pkt and can download in this <thread link>
You need to use it as reference parameter overwrite. Like value 1 = 0, value 2 = 0.225 use linear then it will calculate from 0 - 0.225 then use it in region length 45m. Please check out the <AU class link> in the thread link above as you can learn alot from that class as well.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
