Splitted Profile View title text has multiple end stations
antonioygeo
antonioygeo
I have a split profile view and I'm trying to create a title text that will contain the Profile View End Station.
However it seems like the station which is splitted, is considered to be an End Station as well. So my title has more than one End Sations.
Is there a workaround?
Current Version: Autocad Civil 3D 2020
MMcCall402
I wasn't able to reproduce this.
Would it be possible to post a file with this issue?
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
antonioygeo
Sure, I've created a new drawing from scratch, because in my drawing there are lots of greek characters.
antonioygeo
Any solution anyone?
MMcCall402
Ok, I think I've got it.
Go to the Profile View Properties and to the Elevations tab.  In the Split profile view data area you'll see profile view styles applied to each of the profile view splits.  Note that the first split has a style of Standard and the others a style of standard No title.  That first split's style is where the duplicate end station labeling is coming from.  Edit the first split's style to also be standard No title and it will stop the duplicate labelling.
It appears that when there is a split that each split section of the view can act as a sort of sub-profile view within an overall profile view.  This can create view titles for each one separately along with one for the overall view.  Your titles were anchored to the left side so their placement coincided.  If they were anchored to the bottom middle it would have been easier to see.
Mark Mccall
CAD Mangler
antonioygeo
Ok, I did so many split views that I totally forgot that the profile view has its own style. That solved my problem.
Thanks a lot.
velenjani.dube
This shows the beginning and end stations for just one of the split profiles,. How do you show the start station of the first profile and end station of the last profile.
On the attached screen shot the title show station 100 to 150. I want show 50 to 150.
Anyone with solution.
The solution should be applicable for multi-splits per section.
