Subassembly Composer (SAC) - React to Parameter Reference Override from Civil 3D
fcernst
Mentor Mentor
fcernst
In SAC I have a link that uses a typical user Input parameter for its slope, then some decisions are made based on the slope value.
In the Civil 3D environment the slope parameter gets overriden in the Assembly using a Parameter Reference.
Is there anyway in SAC to read that overriden slope value (downstream in SAC after the original slope value from the Input parameter was used)?
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
KMercier_C3D
If the link that is being modified is L1 and then in further definition in the pkt you reference L1.slope that should use the overridden L1 slope.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
fcernst
I tried that with AL1 that first uses a Grade Type Parameter I called DefaultSlope entered by the User, then used a Decision with the argument AL1.slope = DefaultSlope and it didn't work for me.
I'll try a regular link.
Fred Ernst, PE
C3D 2027
Ernst Engineering
RonaldBrañez
Hi @fcernst,
You could define a variable and assign the value to be replaced before making the change and call it later where you need it.
