Civil 3D Forum
Showing combined factor value and original value in a curve data
1 REPLY 1
231 Views, 1 Reply
Anybody can help me to solve this problem.
The received TOPO survey combined factor scale is 0.999591760. I already applied this scale in the STA (station) without changing the displayed STA value.
(Eg:- The displayed STA value 1+100, 1+200, 1+300… So the distance between two point will be 100.00 but real distance is 99.959 in manual measurements as per combined factor). this is solved by Mr. ionescu_dragosWHU3X using ‘Expression’ tool. If You feel any mistily please see the post titled “ TOPO Survey combined factor applying in civil 3d”
Now I am having some issues with curved area —In our project all horizontal bends in Pipeline are in 210.00m radius. Here, I need to show combined factor value and original value at curved area (See Capture01). Can you please explain how can I callout both of them at a time. Now I’m doing for this by choosing curve radius as 209.914 instead of 210.00. But I am getting either of them. I think it is possible through ‘Expression’ tool. I tried to catchup but absolutely I failed.
Thanks in advance for any tips!
COMBINED FACTOR = 0.999591760
Original radius 210.0m
1 REPLY 1
I solved this issue by me.
see the step.
Toolspace -- Settings--Alignment--Label styles--Curve--Expressions
right click-- new--
type as below
Name: Radius to Scale
Expression: Radius*.999591760
OK
then apply this in Delta over Length & Radius as per attached images.
thank you
Rail Community
