Civil 3D Forum
short straights between reverse curves
1 REPLY 1
oliverkisera
128 Views, 1 Reply
Hello engineers, I have an alignment that some parts needs reverse curves, is it wise to add short straights between reverse curves or the super-elevation transitions can still be smooth even without the short straights, will really appreciate your responses, thanks
1 REPLY 1
Joe-Bouza
in reply to: oliverkisera
Kind of depends on the use and design speed. AASHTO and probably many DOT's in the states would want them to be a minimum length. This is so the driver eases into the opposite turn.
Joe Bouza
Rail Community
