Section View no display labels correctly
Hi !
I would like to know, how display indywidual  point code on  section  view from point corridor.
Here u get ss, if u look  on this - u  see, that i  can display labels where "no  point" code included - ofc i  want dispaly code only whre i  want.  ( "P", :"KJ"
  etc etc...)
Replies (16)
Mike.M.Carlson
Hello-
Watch this short video.  It steps through the process of setting up your drawing to handle corridor point code labeling in your section views.  There are several little settings you have to dial in for your subassembly point codes / associated code set style, and Section Label Set.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
HI,  I  saw this solution  couple times ago.
But for my - it's not working and I  really not know what i make bad.
Something going wrong,  when i  try make any  section / corridor points /  style  -  it's always empty style in corridor point label style.
ok, i  create a complete new drawing,  and it's work.
maybe i clear my old files.
I purge old drawing, make a lot of thigns, but in  new file work fine but in older no  way to  get this labels from  corrdior points.
I attach  2 file, where u  can see some big problem  with compatibility witch  older template drawing seetings.
On 2018 it's work  fine
When i  try make the same steps using our company template (2017 ) - it's fail.
Futhermore, is not the only one big problem with thiss issue -  here i  had the same problem ( but witch pipe)
https://forums.autodesk.com/t5/autocad-civil-3d-forum/c3d-2018-pipe-network-change-elevation-automat...
If autodesk make nothing with compatibility ,  will  be so f*** nice to write temaplate sheet again  and agian with new version  on civil....
Mike.M.Carlson
Hello-
Since you have your section views already created and you have created your Section View Label Set that specifies the new Corridor Points style label you created (per the video).
To get your section views to update, you need to run a command that will convert the default Code Set Style Labels to the new corridor Points Style Label.  Type: CORRIDORSECTIONLABELSCONV
TYPE: ALL
SPECIFY: CORRIDOR POINTS STYLE LABELS
You will notice all your current labels in your section views will disappear.  Just select one of the Section Views and right click and chose Section View Group Properties.  Then Under the sections tab, add new corridor points label set to your corridor.
Please watch workflow below:
Jeff's video I sent earlier discusses this important step at 6min 17 seconds...
I would also re-watch it to make sure your .dwt is set up correctly the next time you create multiple section views...there are command settings that were not set in the 2017 file you sent.  Again this is only applicable for new section view creation.
Michael M. Carlson
CADD Manager
Thx for replay.
I watched Jeff video couple times, but here watch  this -  for me it's  comprehended...
I use this command :  CORRIDORSECTIONLABELSCONV  them  select from point corridor. I switch in setting draw too ( 4:30 Jeff video), regen  file, make really the same steps but no  good results...
I  attach  my project.
teren -  terrain
oski -  alligment
korytarz -  corridor
przekroje poprzeczne -  secition view
I use shortcut's
If u  fix this file, please make video them i belive that it's possible.
 http://www59.zippyshare.com/v/rS7sQbpq/file.html
 help ?
Jowennl
Hi LafPL
Please see attached screencast to show the solution to your question. I used two of your drawings as examples.
Quick Summary
  • You need to fix settings command in your Section ViewOnePieceOfThePuzzle.jpg
  • Update your code set style, Under Point and Label Style.
  • Make 2 Label style one for point code and second for description.
For further information about Cross Section via Surface see this thread which I discuss XS samples.
https://forums.autodesk.com/t5/autocad-civil-3d-forum/section-view-information-not-displaying-as-i-w...
or
See my screencast about Civil 3D Cross Section - Samples
https://knowledge.autodesk.com/community/screencast/237ceced-6e54-4875-8a69-4df34119e416
Hope you guys learn something.
Cheers,
Jowenn
thx for repplay but your solution it's not good enaugh
1st.  - u edit style of corridor , not label style.
In  Jeff wideo we know, how should this work ( at. 6.00)  -  style defined only where label must show, but label style define how its should looks.
In your solution i  can't stagger label  ( Jeff viedeo 3.33)
here i  create a idea, meybe someone vote, and we will  be closer to solve one problem.
GZE
Old post but I can not label cross section using point code labels (staggered) I tried to follow procedures above but failed to display labels
Humphrey GZE
Civil 3D 2013 64bit SP1
Elitebook 8540w
Core i7 2.8GHz, 8Gig RAM
NVIDIA Quadro FX880
160Gb SSD
Sinoj.Ravindran
Hi Jowennl,
Thanks for the video regarding corridor code set styles to show up in the section view band.
In that video you didnt showed how you created natural ground levels in the same vertical line as of corridor point code location labels.
Can you please guide how to do that ?
Regards
lynn_zhang
Hi @Sinoj.Ravindran
I see @Jowennl has addressed the issue and answered your question in the other post: https://forums.autodesk.com/t5/civil-3d-forum/corridor-code-set-style-labels/m-p/9423470#M422207
Let us know if you have any further questions!
Lynn Zhang
Sinoj.Ravindran
Hi Lynn,
Its done and perfect as Jowenn explained very well and clear.
Thanks to him for taking time to answer.
Regards
