SE data band labels not appearing
pics.munmun
Message 1 of 10
pics.munmun
Data band labels are not appearing on band data
Replies (9)
Message 2 of 10
ecfernandez
Hi @pics.munmun, did you check that those layers are not frozen? sometimes it happens
Regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
Message 3 of 10
pics.munmun
@ecfernandez. Layers are not frozen.
Message 4 of 10
patrick_ericson
How about the layers in Layer manager? Are they not frozen aswell?
Message 5 of 10
ecfernandez
Hi again
frozen layers are not the same as turned off layers. Indeed, what you posted is just the proof that those layers are turned on, but in that window you cannot check if they are frozen.
What I meant was, as @patrick_ericsonmentioned, to enter the layer manager and see if those layers or any object layer are not frozen.
regards
Camilo Fernández
LinkedIn
Message 6 of 10
MichaelH13
Make sure they are also turned on in the profile view, not just the plan view, in the band style.
Message 7 of 10
pics.munmun
@ecfernandez  and @patrick_ericson
the layer is not frozen
Message 8 of 10
pics.munmun
Hi @MichaelH13 , There is no option of profile view. Only plan view is available.
Message 9 of 10
patrick_ericson
True, I saw that when I checked the styles.
Regarding layers
If you compare the layer visibility in Layer manager and in the style-display tab
Are they all visible as in my example?
Message 10 of 10
ecfernandez
Hi again, guys. If all the layers are turned on and not frozen, then you must check the Layout tab of every band detail in the section Labels and Ticks. (see the image)
Go to your superelevation band style commonly located here
Open your style and then go to "Band details," then go to every single component of the section "Labels and ticks" and open it by clicking "compose label." When there, make sure that in the "Layout tab," each of those components shows the information you need. If the text component editor is empty, any label won't appear in the model.
If this is the case, then add the information to the text component editor (in the image I posted, you can see the station value is assigned to the component Normal Crown, and therefore, it is visible in the model), hit OK, and then go back to keep checking the label components.
I hope this helps. Best regards!
Camilo Fernández
LinkedIn
