How to change Alignment length
RalphBrown99
RalphBrown99
Hi know that this is super-easy but just wondering how to change an alignment length?
Regards
Ralph
TerryDotson
You can grip edit the endpoint of an alignment which effectively lengthens it, but otherwise there is no length property that can be changed.   Civil3D will automatically adjust the segments to maintain tangency to the end point.  If there are other ways hopefully someone will chime in on the method(s).
kamalgaramja556
Select the alignment go on geometry edit and do what you want.
neilyj666
You can also change the starting value of the chainage if you need to (while keeping the same absolute length)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
RalphBrown99
Hi Terry and Kamal,
It looks like something is going on, the alignment does not generate grips. I will talk to you later on
Ralph
AllenJessup
@RalphBrown99
If you can. Post the drawing.
Allen Jessup
CAD Manager - Designer
Cadguru42
@RalphBrown99 wrote:
Hi Terry and Kamal,
Ralph
Is it a data reference alignment? You won't have grips when it's a DREF. You'll need to edit the alignment in the source drawing.
C3D 2024-2026
Windows 11
32GB RAM
