same data but c3d draw 2 different locations
arshadmirza786
arshadmirza786
The data in .xls file is same for drawing a line with "LL" and points with "NE" commands but on screen the boths commands draw in different locations ie in RED CIRCLE & YELLOW CIRCLE is the correct location
What is wrong with me How can get the same at same location
tcorey
Whether you are calling it Northing and Easting or Latitude and Longitude, the data in your xls are all Latitude/Longitude. Some columns are in decimal degrees and others are in degree minutes and seconds.
Treat all these data as LL and set your drawing's ambient settings to the property LL type (decdeg vs. dms) and you should be able to correclty merge the drawings.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Pointdump
A,
I can't open your 2017 drawings, but looking at your Excel data, I agree with Tim.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
arshadmirza786
The improved data is attached
The B/W data is for Long/Lat (LL) and the red is for Northing/ Easting (NE)
and the position is still same
Pointdump
Columns A and B are in Degrees and Decimal Minutes.
Columns I and P are in Degrees Minutes Seconds.
Columns R through V are in Decimal Degrees, not Northing/Easting.
For the black numbers, Columns A - P agree, albeit with different formats.
The red numbers do NOT agree with the the black. N30D59'23.64" does not equal 30.990673 and E72D10'13.68" does not equal 72.172428.
So which columns contain the original data?
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
A,
I'm guessing the first column of your data is Degrees-Minutes, and is the original data. Does this look like it's in the right area?
In the attached drawing I imported the Degrees-Minutes points. Notice the UTM84-43N Northings and Eastings.
Dave
Dave Stoll
Las Vegas, Nevada
