If I delete a survey database by mistake, is there some way the same can be recovered?
Look in your Windows Recycle Bin. That would be the only way.
Your other option may be to ask your IT person for help restoring the survey.sdbx file from backup. Once you find it you may just copy it into your Working Folder.
I checked. Did not help. I had to recreate everything from scratch. Took me a while. I have done it now. I hope AutoDESK creates an opportunity to recover the survey database in such cases of mishap.
If you are lucky enough to recognize your mistake the instant it happens, you can undo the deletion. Ctrl Z has saved me before.
