Civil 3D Forum
Recovering Survey Database
4 REPLIES 4
414 Views, 4 Replies
If I delete a survey database by mistake, is there some way the same can be recovered?
4 REPLIES 4
ToddRogers-WPM
Look in your Windows Recycle Bin. That would be the only way.
Todd Rogers
AlmasSuljevic
Your other option may be to ask your IT person for help restoring the survey.sdbx file from backup. Once you find it you may just copy it into your Working Folder.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
in reply to: AlmasSuljevic
I checked. Did not help. I had to recreate everything from scratch. Took me a while. I have done it now. I hope AutoDESK creates an opportunity to recover the survey database in such cases of mishap.
sconteE5KP8
If you are lucky enough to recognize your mistake the instant it happens, you can undo the deletion.  Ctrl Z has saved me before.
Rail Community
