Civil 3D Forum
Publish prints layout tiny in lower left of screen
1 REPLY 1
ODO18
275 Views, 1 Reply
We have experienced a quirk with publishing where it publishes the sheets tiny in the lower left corner.  The solution we have found at the moment is when publishing select the “Publish to:” drop-down window and change it from “PDF” to “Plotter named in page setup” and then change it right back to “PDF”.  Is this a known issue that others are seeing?
We are using Version 13.3.2105.0 Civil 3D 2021.2 built on top of R.154.0.0 AutoCAD 2021.1.1 and 24.0.30.17 Autodesk AutoCAD Map 3D 2021.0.1.
Thank you
Labels (2)
1 REPLY 1
bryan
in reply to: ODO18
I also have seen this on some client's machines. I cannot reproduce the error on my own machine.
Rail Community
