We have experienced a quirk with publishing where it publishes the sheets tiny in the lower left corner. The solution we have found at the moment is when publishing select the “Publish to:” drop-down window and change it from “PDF” to “Plotter named in page setup” and then change it right back to “PDF”. Is this a known issue that others are seeing?
We are using Version 13.3.2105.0 Civil 3D 2021.2 built on top of R.154.0.0 AutoCAD 2021.1.1 and 24.0.30.17 Autodesk AutoCAD Map 3D 2021.0.1.
Thank you
