Pressure pipes cataloger not recognizing pipes?
Erich_Raska
Erich_Raska
 I am working with the Pressure pipes which has worked great, until now...
I am trying to load the "AWWA Mech.sqlite" but when I am creating a "new parts list" under the settings tab I add the pipes and they show up until I go to actually create them. I have also noticed that when adding the pipes to the "Pressure Pipes", that their is no longer a name any more for the "Pressure Pipes". I thought it had said "ductile" on the second "+" down. The first "+" being the "Pressure Network Parts List Name", the second "+" being the Pipe group you have added. Third "+" being the pipes by sizes and material... The second "+" is empty. the third comes in fine.
Once in the drawing and creating the actual pressure network, nothing shows up under the layout, pipe "size and material" for "Pressure Network Plan Layout:1" its just blank...
I have attached my catalog just so someone can check to see if they are seeing the same thing. Do they get corrupts?
Please help...
Erich_Raska
This was a .cuix issue.
I cleaned up the custom files and it fixed the problem. Not sure how to delete the thread though?
