Layers automatically loading on new drawing
Message 1 of 10
good afternoon,
i would like to know how to prevent the ecessive amount of layers that automatically load whenever i select a tab to create a new drawing. the layes auot-populate in my layer properties managerand make it very difficult to navigate to my created layers as well as use the dxf or dwg for any other application. Capture3.JPG
Replies (9)
Message 2 of 10
Jeff_M
Welcome to the forums, Matthew! Those layers are all contained in the Drawing Template that you have set as your QNew dwt. Edit the DWT to contain only those layers you want/use.
Jeff_M, also a frequent Swamper
Message 3 of 10
Just to add, those layers exist because they are defined in the various pre-made Styles in which the relevant objects will be placed in. So if you don't want a certain layer, you'd have to find the styles that are using that layer; else you won't be able to delete the layer.
Message 4 of 10
redtransitconsultants
Additional to a layer being tied to a style, there are predefined Object Layers. Go to Toolspace, right click Edit Drawing Settings, Object Layers tab to view these layers.
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Message 5 of 10
rl_jackson
Also to add wat others have said. A quick way to remove all of those layers is to use the merge layer command and send them all to 0. This will retain the styles ab place everything on layer 0 within the styles. Aduit the drawing after doing this several times to remove errors.
Rick Jackson
Survey CAD Technician VI
Message 6 of 10
Pointdump
Matthew,
Layer Filters are a good way to deal with an Infestation of Layers:
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/documentation/CIV3D/2012/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4a98-htm.html
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-5818FE81-B822-45AC-BAB0-3517376EA402-htm.html
Dave
@Pointdump - This reply has been edited by the moderation team as the legacy links were no longer valid
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 7 of 10
neilyj666
I second this approach - it's worked well for me
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 8 of 10
hemtopo
Community Visitor
Community Visitor
Thanks Jeff, I created a copy from template, then I delete all layers with LAYERDEL command (except layer 0) and work perfectly.
Message 9 of 10
tcorey
 Those layers must exist in the template if they are referenced by styles and settings.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 10 of 10
stevenh0616
@tcorey Styles yes, object layer settings no. Object layer settings have to exist to assign, but you can delete with LAYDEL and they will recreate (white and continuous) when specific objects are used. settings of the layer does not matter because styles control the display.
Steve Hill, Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
