I am using Civil 3D 2015.
I am not familiar with pressure pipes yet and my company is looking for a software that designs and analyses pressure pipes and pump stations. I know Civil 3D has pressure pipe networks, but does the pressure networks also have analysis and design capablities? If so, is it capable of lift station and pump design?
Solved by bcmonsen. Go to Solution.
Solved by ToddRogers-WPM. Go to Solution.
You should use the Storm and Sanitary Analysis that comes with Civil 3D. For water analysis, you are better off using something like WaterCAD.
A few years ago Autodesk bought WaterNET, StormCAD, and RiverCAD from BOSS International. Two of the three were turned into Civil 3D applications. Not sure what Autodesk's plan is for WaterNET.
I wish they would do something with the WaterNET because we have customers ask us all the time if Autodesk has anything, and unfortunately, I have to turn them to WaterCAD. But, that USED to be the case for AutoTurn as well and now they have a product that kills AutoTurn.
I just saw there is a new pressure analysis tool that is using the EPANET program inside of Civil 3D called PressureCAD. It has worked great for us! www.pressurecad.com
