Point cloud x and y coordinates appear to flip after inserting point cloud from drawing object.
dbartholPQYPW
dbartholPQYPW
I inserted a point cloud that I processes in Recap Pro. The point cloud appears to insert to the correct coordinates but as soon as I "insert points from drawing object", it appears to flip the x and y coordinates.
Pointdump
Hi David,
Please post a link to your point cloud.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Pointdump
David,
Whenever you insert a point cloud into a drawing, first use command UNITS to set "Units to scale inserted content" to whatever your target system units were in ReCap.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
David,
I had a closer look at your drawing. If you turn off the Transformation Tab, use command GEOREMOVE, re-assign VA83-SF, then everything works as expected.
Dave
Dave Stoll
Las Vegas, Nevada
dbartholPQYPW
The point cloud inserts correctly but when I create a surface from point cloud, it does not appear to create a correct surface. The surface shows up in prospector but when I run a quick profile to check, nothing shows on the profile.
Here's a link to the files:
https://bdadevelopmentservicespllc-my.sharepoint.com/:f:/g/personal/daveb_bdaland_net/EjkzHMNjAoxGgg...
