PIPE NETWORK SHP FILE ISSUE FROM GIS IMPORT
Jawed-Sheikh
Jawed-Sheikh
HI Folks,
I am facing an issue since I switch into C3D 2024 , when I am importing shp file of Pipe network through import GIS Data the all curve pipes break and loose inverts while straight pipes are correct. I will share screen short for your review, advise and solution. Please help.
Regards
M- Jawed Sheikh
TerryDotson
The primary problem is that the ShapeFile specification itself does not provide for curves.  While there are different types of geometry in the spec and a measure field could be used to store a bulge factor, it's highly unlikely you would get any two providers (let alone all) to use the fields to store curve data.
That said the short segments could be evaluated and curves could be restored after the import.  There are not any current tools available for this on pipe networks that I'm aware of, but it could be addressed in the near future.
Consider posting a drawing with your pipe part definitions and the shapefile collection (all files, not just the .SHP) and myself and others could make better recommendations.
rl_jackson
I could be wrong here, but I don't believe C3D Pipe Networks can have a curved pipe. It can replicate a curve by pipe deflection, but not a true curve, this could be why the import is failing.
Rick Jackson
Survey CAD Technician VI
Jawed-Sheikh
Until C3D 2023 VERSION Life was good, Its happens in 2024 version. 😓
Jawed-Sheikh
PANORAMA ERRORS:
lim.wendy
Hi Jawed,
Thanks for reaching out to the forum. As mentioned by other experts, please share the drawing so we can take a closer look.
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Jawed-Sheikh
@lim.wendy
I have attached the drawing and shapefile folder as a zip.
Hope to hear from you soon.
