I have 2 profile sheets and when I plot my entire sheet set thru SSM sanitary and storm do not show up in the profile sheets. When I only plot the profile sheets thru SSM it appears fine. Even if I plot only 1 plan sheet and the 2 profile sheets and storm and sanitary again don't show up in the profile view.
It is difficult to know exactly what could be causing this without a file to troubleshoot with. Can you share the file for us to take a look at?
I would check the drawing, xrefs and data shortcut source drawings (if any) for errors with the Audit command.
