Civil 3D Forum
Pipe network alignment overrides
3 REPLIES 3
Kozak_MJK
1314 Views, 3 Replies
I am using Civil 3D 2014 and I am having a problem with my pipe network overrides. The current project that I am working on has multiple street alignments that cross at intersections. In my plan and profile, I need to reference the alignment that I am focused on for that sheet so that my structures are labeled with the corresponding stationing and offset. If I have a structure that is in an intersection, I need to reference one alignment in one drawing and another alignment in another drawing. If I sync, the structures revert back to the parent drawing settings. I have tried setting up overrides in the individual drawings but will still lose the information if the drawing sync's. Does anyone have any ideas on how to force the overrides onto the referenced pipe networks?
Matt Kozak
3 REPLIES 3
Jay_B
in reply to: Kozak_MJK
Try setting the reference alignment by selecting structure label > rt click > label properties > reference alignment.
Then it should stay assigned to the desired alignment following a sync ref's..
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Kozak_MJK
in reply to: Jay_B
Perfect! I did not know that option was in there. I kept looking for a child object override.
Thanks again!
rkmcswain
Interesting because that does not update the Referenced Alignment for the structure, only the label that is referencing the structure.
Unfortunately, there does not seem to be a way to update a table, since the table does not have an editable property "Reference Alignment"
It looks like tables simply pull the data live from the dref'ed pipe or structure and if that entity does not have a Reference Alignment, then you get "??????" for the station and offset.
R.K. McSwain     | CADpanacea | on twitter
Rail Community
