Civil 3D Forum
LAS point cloud import; how do I convert XY from degrees to feet?
13 REPLIES 13
Message 1 of 14
1377 Views, 13 Replies
I'm trying to bring in a .las file into Civil 3D, but it's not coming in correctly. The coordinate system of the file is WGS84. I set the projection in my drawing file to match, but when I bring in the point cloud, it seems to read the degrees of the XY maximum and minimum as feet. I cannot find where to fix this.
13 REPLIES 13
Message 2 of 14
AllenJessup
Do you have a small LAS file you could share. That way we could experiment with it.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 14
in reply to: AllenJessup
Hello Allen,
The smallest one I have is 251 MB. I'm not sure what the file size limit is here.
Message 4 of 14
AllenJessup
Yeah. That's too big and I can't access Dropbox or anything like that. Does it happen to be public source? Is there somewhere I can download it?
Allen
Allen Jessup
Message 5 of 14
I should have thought of that. Link:
https://www.dropbox.com/s/5wwxf40t7ufep5i/150409_NVPSite_points.zip?dl=0
You can download directly from the link without Dropbox.
Message 6 of 14
AllenJessup
Unfortunately I can't. I'm blocked from anything that has Dropbox.com. Hopefully someone else will give it a try.
Allen
Allen Jessup
Message 7 of 14
Thanks anyway!
Message 8 of 14
gccdaemon
Have you tried setting the drawing units to metric? Just an idea. I can do point clouds, but don't know much about WGS location.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 9 of 14
in reply to: gccdaemon
I tried that, along with changing the drawing coordinate system. The problem is that it seems to be interpreting the lat/longs as linear coordinates, so what should be about 48 acres comes in as .0061 ft. .0061 m wouldn't be any better.
Message 10 of 14
gccdaemon
I think I know what you're talking about now. I have had the same problem with FEMA data. I think you'll have to use ARCGIS or some other GIS software to translate it into state plane coordinates. I wound up having our survey dept fix it...lol.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 11 of 14
Maybe I can talk my boss into getting Spatial Analyst. ET vtools doesn't import las files.
Message 12 of 14
AllenJessup
It looks like the LAS2LAS.exe from https://www.cs.unc.edu/~isenburg/lastools/ might do it. But it doesn't look too user friendly.
Allen
Allen Jessup
Message 13 of 14
Boy, am I ever stoopid. The answer is right there in the dialog box when I import the point cloud. Set the drawing coordinate system for what it needs to be, then set the cloud coordinates for what they are, in this case WGS84 LL, then let the computer do the work.
Message 14 of 14
gccdaemon
Glad you got it figgured out. Don't forget to mark it as an answer!
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
