Civil 3D Forum
PARCEL TABLE
4 REPLIES 4
nostupidquestions
1163 Views, 4 Replies
PARCEL TABLE
i've got some parcels in my subdivision that are pretty small and the label is too large for the parcel. so i though i would use a parcel table for these parcels. however i can't get the table to allow me to remove the parcel number column. my parcels use letters instead of numbers so i can't substitute the parcel name. all my parcel info is in the description. how can i remove the parcel number column of use text instead of numbers for the parcel name? thanks.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
4 REPLIES 4
igi_pop
in reply to: nostupidquestions
hey!
weeeell, you can't. Parcels are not the only ones, most tables don't allow removing the # column, thusly ensuring uniqueness of the data.
What you CAN do, is to delete the column title, column data, and manualy set the width to -2 (someone somewhere wrote that, thanks, tried and works) then it just won't be visible. Does it work for you - dunno. But if it's just "poking yer eyes" that's the solution 🙂
Your 2nd column can be your text, and you can sort data by "column 2"
Cheers
Lenovo ThinkCenter M920f; Win10pro x64; i5 9500 @3GHz; 16GB RAM; Radeon RX550X
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
nostupidquestions
in reply to: igi_pop
genius! i tried setting that column to zero with no luck. thanks for the help!
64 GB RAM
C3D 2023.2
Jeff_M
You can also Copy-Paste the Description property from another column and put it into the first column, thus overriding the Number or Name.
Jeff_M, also a frequent Swamper
I can confirm the -2 option mentioned above works in Civil 3D 2021.  Great tip!
Attitude, not Aptitude, Determines Altitude
Rail Community
