i've got some parcels in my subdivision that are pretty small and the label is too large for the parcel. so i though i would use a parcel table for these parcels. however i can't get the table to allow me to remove the parcel number column. my parcels use letters instead of numbers so i can't substitute the parcel name. all my parcel info is in the description. how can i remove the parcel number column of use text instead of numbers for the parcel name? thanks.
Solved by Jeff_M. Go to Solution.
Solved by igi_pop. Go to Solution.
hey!
weeeell, you can't. Parcels are not the only ones, most tables don't allow removing the # column, thusly ensuring uniqueness of the data.
What you CAN do, is to delete the column title, column data, and manualy set the width to -2 (someone somewhere wrote that, thanks, tried and works) then it just won't be visible. Does it work for you - dunno. But if it's just "poking yer eyes" that's the solution 🙂
Your 2nd column can be your text, and you can sort data by "column 2"
Cheers
genius! i tried setting that column to zero with no luck. thanks for the help!
I can confirm the -2 option mentioned above works in Civil 3D 2021. Great tip!
