GOOD DAY, I AM STILL GETTING OUT OF DATE SIGN AT BOTH OF MY CORRIDORS (EDO DELTA AND EDO NIGER) AT MY INTERSECTIONS. WHEN I REBUILD THE CORRIDORS, THE OUT OF DATE SIGNS WILL ALMOST RETURN IMMEDIATELY. I DON'T EXPERIENCE SUCH WITH THE OTHER CORRIDOR (OSBORNE CORRIDOR). I AM USING 2016 VERSION. WHERE DID I GO WRONG AND HOW CAN THIS BE FIXED?
Solved by Jowennl. Go to Solution.
Hi @fiyahe7981 ,
Corridor will be out of date if you change your target, or update you assembly, or update your alignment.
If you wish the corridor to automatically update then all you need is to click the Rebuild Automatic in your corridor. Also, from time to time if the rebuild automatic won't update then simple force it to rebuild by clicking rebuild.
See guide below and sample dwg.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
Hello @fiyahe7981 ,
Just checking to see if your problem has been solved. Did the suggestion from @Jowennl help solve the issue? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
