Civil 3D Forum
OUT OF DATE CORRIDOR
2 REPLIES 2
fiyahe7981
1229 Views, 2 Replies
GOOD DAY, I AM STILL GETTING OUT OF DATE SIGN AT BOTH OF MY CORRIDORS (EDO DELTA AND EDO NIGER) AT MY INTERSECTIONS. WHEN I REBUILD THE CORRIDORS, THE OUT OF DATE SIGNS WILL ALMOST RETURN IMMEDIATELY. I DON'T EXPERIENCE SUCH WITH THE OTHER CORRIDOR (OSBORNE CORRIDOR). I AM USING 2016 VERSION. WHERE DID I GO WRONG AND HOW CAN THIS BE FIXED?
2 REPLIES 2
Jowennl
in reply to: fiyahe7981
Hi @fiyahe7981 ,
Corridor will be out of date if you change your target, or update you assembly, or update your alignment.
If you wish the corridor to automatically update then all you need is to click the Rebuild Automatic in your corridor. Also, from time to time if the rebuild automatic won't update then simple force it to rebuild by clicking rebuild.
See guide below and sample dwg.
Cheers,
Jowenn
lynn_zhang
Hello @fiyahe7981 ,
Just checking to see if your problem has been solved. Did the suggestion from @Jowennl help solve the issue? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Rail Community
