Osnap and Selection Cycling
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have Civil 3D 2015. This could be a general AutoCAD 2015 issue.
I am having problems with OSNAPS. SOMETIMES but not all of the time, when I try to select a point using an osnap, the selection cycling box will come up giving me the option to select a particular line, point, etc., whatever the case may be. I can cancel the command and repeat the exact same steps and then it will not happen.
I cannot understand why the selection cycling box comes up when I am in the middle of a command, like MOVE for instance, and I have an osnap active. (I have already selected the object to move, hit ENTER, and it is asking for the base point. Whether I have running osnaps on or just activate one (I have mine on a toolbar), when trying to snap to the base point or the second point of displacement, that is when the selection cycling box will come up.) (It happens with all commands not just MOVE.)
I like to use selection cycling, because I have a lot of overlapping objects. But it is interfering with my osnaps somehow.
I did not have this issue with 2013 or 2014.
Does anyone know what I can do to fix this? Has anyone else experienced this issue?
