Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Civil 3D Forum
Code Set Style
1 REPLY 1
Mogwai83
220 Views, 1 Reply
Code Set Style
Hello!!!
In the codes tab in corriodor properties there is a drop down menu (Code Set Style). Currently there are Assembly Creation, Plan View, Plan view wth Hatch etc on the drop down menu.
I have made a custom Code Set Style, How do i make it that my custom Code Style will show evreytime in the drop down menu? Its doesn't seem to appear when I start a new drawing.
Tags (1)
1 REPLY 1
Jay_B
in reply to: Mogwai83
Make sure to add the new Code Set Style to the template being used to create new drawings.
This way it will always be present in every new drawing created.
The template used to create New drawings is set by the QNEW variable which can be specified in OPTIONS.
Options > Files Tab > Template Settings > Default Template File Name for QNEW.
To import the code set into other drawings run the _ImportStylesAndSettings command or drag n drop between dwg's.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
