ODD (fractional) scale factors
ESchomberg
Message 1 of 10
ESchomberg
Dear sirs. I received 2 drawings from the same client that I have been working for. This time when I opened the two drawings.....no matter model/or paper space....when I try to scale my drawing "like I normally do" the only options for scaling is in fractions. Such as:1/4"= 1.0'.....There are no options(that normally come up) such as 1"=30' OR 1"=100'.......Please help......I can't work on a drawing like that.
Replies (9)
Message 2 of 10
rl_jackson
To get the scales to come up within the drawing sent to you need to go to bottom right as shown below and select custom.
From there another dialoge box will open were you can either add or delect scales or reset the scale list.
Now I have found that I always need to hit the Metric & Imperial to load all scales for this to import the scale list correctly.
Another option (best option) that may better suit your needs is to insert the original drawing as a block into a blank drawing based on your template file, this will bring all the settings (most importantly ambient settings) that you have changed along with the styles you have created along for the ride.
Rick Jackson
Survey CAD Technician VI
Message 3 of 10
Joe-Bouza
Type UNITS, if it says Architectural you will need to convert. Presuming it is for background, I would xref it into you clean template at a scale of x=1/12, y=1/12.
If not follow @rl_jacksons advice.
Joe Bouza
Message 4 of 10
ESchomberg
Thanks guys. The units box came up(nice trick to know) everything was correct. The other gentleman showed me how to reset the scale list(that worked). Hopefully I won't face this on every drawing, because talking about xref drawings and inserting drawings into other templates I am lost.
Message 5 of 10
Pointdump
Erik,
So you haven't plunged into Xref's yet? Well, my man, Rabbit Hole #437 awaits you:
https://www.youtube.com/watch?v=6nUwn7FRiiI&index=29&list=PLXEyem_18syOEpO-jBqnZTvGLIE7K1rxV
This is a one-hour long webinar. Put on a pot of coffee.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 6 of 10
ESchomberg
Lol, thanks.....hey Dave do you and/or most of the guys on here work for yourself at home, or work at an office for a company?
Message 7 of 10
ESchomberg
Dave, I am working from templates that were given to me and when I browse the line-types and symbols that you guys gave me it does not give me the option to get to the folder that I put them in. Is there a simple way to insert these lin files and symbols into a template? Would I click on the "insert tab" in the ribbon bar?
Message 8 of 10
Pointdump
Erik,
You can store those linetypes anywhere you want :
http://cadtips.cadalyst.com/object-data/locate-linetype-files-quickly
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 10
Pointdump
Erik,
Re: Work
Work? What's that? Been pretty spotty since the Crash of '07.
I'm an old field guy--Layout Carpenter, Instrument Operator, Grade Checker. On some of my carpenter gigs I use C3D (on my own time at home) to calc layout points for total station layout. Hence the name Pointdump. But as for paid C3D work in a survey office, I've worked a total of 2 days. 4 if you include work with LDT at a civil a year-and-a-half ago. I rarely see the inside of an office. Mine is a world of backhoes, scrapers, blades, dozers, and readymix trucks.
Civil 3D is my hobby. Learning about it is enjoyable, and endlessly fascinating.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 10
ESchomberg
