Civil 3D Forum
OBJECT TURN OFF
27 REPLIES 27
Message 1 of 28
phogak01
1376 Views, 27 Replies
OBJECT TURN OFF
CIVIL 3D. Insert point to create SYMBOLS - EXPORT (drawing) - FLATTEN. All the objects are on BLOCK REFERENCE. I try to turn off the OBJECT and it wont turn off? See picture for reference. Thank you
Tags (1)
27 REPLIES 27
Message 21 of 28
Joe-Bouza
in reply to: phogak01
Even in latest drawing : plain AutoCAD I can turn off every symbol with the exception of a few traffic arrows that are on layer 0 , put on marking  layers and they turn off
Joe Bouza
Message 22 of 28
Joe-Bouza
Are you kidding ? there are only 20 layers in this drawing.
all the symbols are defined BYBLOCK not a fan. define BYLAYER then the snowflake can be used
I read all the help and web potentates explain BYBLOCK and I come away with just as empty  a head as I went in. I just don't get it.  If i want different colors in the block define them on a layer. much easier to comprehend in my pea brain
Joe Bouza
Message 23 of 28
phogak01
in reply to: Joe-Bouza
See attachment. I can turn it off using the layer management but using ribbon panel? it wont turn off im getting this message (BLOCK REFERENCE-2). Thank you
Message 24 of 28
Joe-Bouza
@phogak01  see my reply in post 22
Joe Bouza
Message 25 of 28
phogak01
Hi Joe,
Check this one try to use the snowflake still wont let me to turn it off.
Thank you
Message 26 of 28
Joe-Bouza
Cadd not available. I will check later
Joe Bouza
Message 27 of 28
Joe-Bouza
this is definitely happening as a result of all your block becoming anonymous.
why they are anonymous ?
test: insert your pedramp block on its layer. executer the snow flake ==> command lined choose settings >> block settings >>> block
touch the newly inserted block and it freezes the layer.
figure out how to flatten your file and maintain the blocks and your will work
Joe Bouza
Message 28 of 28
phogak01
Thank you it working now
Rail Community
