Object(s) added to DB too late during save.
AllenJessup
Mentor Mentor
Message 1 of 37
AllenJessup
I have a drawing containing a couple of Surfaces. I keep getting the "Warning: An error occurred during save. We recommend you run RECOVER on the drawing" error during a save. I wanted to copy paste to a new drawing to get rid of that. When I try to Select > All and the do a clipboard Copy. I get the following error.
Object(s) added to DB too late during save. Handles 12D2 to 12D2
12D2: type AeccDbRootSettingsNode, owner 7E (AeccDbTreeNode)
I've tried Audit and Recover. No errors detected. I've purged the drawing using DWG-PURGE, which will purge reggapps and DGN data. I Wblocked the drawing and inserted it into an new drawing from our template. I still get the error when trying to copy to the clipboard.
Allen Jessup
CAD Manager - Designer
Replies (36)
Message 2 of 37
J.FOCHT
Hello @AllenJessup!
This is certainly an interesting situation. The only reference close to the problem you are having is when this same error occurs while working on a user made intersection assembly. This is the only AKN article i could find. Seems like it is a known issue. They suggested the same things that you have already tried. The other suggestion is to make sure all the layers are thawed and try the copy at that point.
Im sure that this doesnt help any but i feel your pain.
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
Message 3 of 37
AllenJessup
Hi @J.FOCHT
Thanks for the reply. I did do a WBlock and insert to new dwg from template. That solved the RECOVER error. I did have all the layers thawed and on the first time. The drawing does have 1 DRef. But that doesn't seem to have any issues with it. Still get the error.
I tried dusting off some of my Lisp skills. I can't seem to select the entity whose handle is referenced. Probably because it's corrupted.
Allen Jessup
Message 4 of 37
J.FOCHT
@AllenJessup,
Are you running LISP actions in this file? Could it possibly be a problem in the save or selection part of one of your LISP routines? If possible you could enable logging in your code and see if it can find any issues. Again, I'm just spit-balling here.
Thank You!
Jonathan Focht
Message 5 of 37
AllenJessup
I do run Lisps and 3rd parties. But nothing has changed and it only happened in the one drawing.
Allen Jessup
Message 6 of 37
cwr-pae
Are you trying to copy both surfaces at the same time? Have you tried coping each separately? If the surfaces are defined by objects in the same file, can you copy & paste the defining objects and recreate the surfaces in a new file?
Occasionally I have noticed ctrl+c and the copy commands from menus/ribbons performing differently (one way fails or triggers a crash, another does not).
Message 7 of 37
AllenJessup
Yes. I was trying to copy everything in the drawing at once. Since I got past that by doing a WBlock. I haven't gone any further with diagnosing it.
Allen Jessup
Message 8 of 37
AllenJessup
This is getting annoying.
Command: _copybase
Specify base point: 41 found
Object(s) added to DB too late during save. Handles 37F to 37F
37F: type AeccDbRootSettingsNode, owner A4 (AeccDbTreeNode)
Allen Jessup
Message 9 of 37
Same problem, is their any Fix?
Message 10 of 37
ANLD
Observer
Observer
Try reloading any exernal reference and then try to save again, works every time for me.
Message 11 of 37
Thanks for the reply,
In my case it was a pipe network label style import from an older drawing.
Save a copy of your drawing and use SELECTSIMILAR on a single label to delete them out. On the manger tab, go to styles and purge unused style. Then try run EXPORTTOAUTOCAD. Kept try different labels until it works and you have found your Corrupted style.  Go back to main drawing and purge out that style.
Message 12 of 37
CADmgrMike
I've ran into this problem twice in the last week. Both of the drawings have been opened in C3D but they are strictly 2D detail base drawings. I even w-blocked everything out to a new drawing and the message pops back up when I try to save.
Mike Porter
https://provostandpritchard.com/
Message 13 of 37
Hi! Somebody have a solution? I have found this problem for Civil3d 2018, 2019, 2020. Solution from Autodesk is to upgrade to 2019.2, but the problem is still here... 😞
Message 14 of 37
AllenJessup
I'd suggest you start a Support Request with Autodesk.
Allen Jessup
Message 15 of 37
gbondoc
Have you tried deleting the entity by it's handle? Put it's handle id in the quotes.
command: (entdel (handent ""))
Message 16 of 37
Neil.Aryan
@AllenJessup,
I have seen another post related to similar issue in forum and also on another platform as well, And successfully they come with some solution. you can refer the same i am not sure its gonna help you.
There is another article on Autodesk Troubleshooting and also i have combined some information and wrote something here.
Hope fully this may be fix the issue and save you time and effort.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
Message 17 of 37
Neil.Aryan
Hi Allenjessup,
How about X-Ref Method?
I had same error with different issue on civil 3d drawing the X-Ref Method resolved the same.
I would suggest you to X-Ref the civil 3d model into your standard template and then Bind and Explode so you can see the civil 3d abjects and other civil 3d elements.
I hope this works and resolve the issue.
I tried for my case and it's worked for me.
Cheers,
Neil
Message 18 of 37
CADmgrMike
I've had this happen on a couple of drawings with no C3D content.
The interesting fix was to rotate the drawing view and then rotate back to World.
Drawing would then save without errors.
Don't ask me why. 🙂
Mike Porter
Message 19 of 37
AllenJessup
@Neil.Aryan
I haven't had this happen for a while. I believe I used a method similar to WBlock and insert. It might have been copy/paste. I haven't seen this at all since moving to 2020.
Allen Jessup
Message 20 of 37
AllenJessup
This seems similar to the WBlock method. It should work as well.
Allen Jessup
