Civil 3D Forum
NOt all points are loading in surface
4 REPLIES 4
328 Views, 4 Replies
I can not seem to get all the points to load when creating a surface. Only the perimeter points are on the surface file? Any ideas on why this is happening?
4 REPLIES 4
Jeew-m
You can go to edit surface style-->display-->turn on points layer and see whether all the points are visible in the surface.
But I think it will be better if you can post the dwg here.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
in reply to: Jeew-m
I have attached the dwg and pts file. Let me know if you see something I am missing.
tcorey
There are no Civil 3D COGO Points in your drawing, only text objects.
First, use _AeccMoveTextToElevation to move the text objects to the elevations they display.
Create your surface, then use _AeccAddSurfaceDrawingObjects to add the elevated text objects to the surface. Be sure to set the Object Type to text.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
in reply to: tcorey
Thank you
Rail Community
