I can not seem to get all the points to load when creating a surface. Only the perimeter points are on the surface file? Any ideas on why this is happening?
You can go to edit surface style-->display-->turn on points layer and see whether all the points are visible in the surface.
But I think it will be better if you can post the dwg here.
There are no Civil 3D COGO Points in your drawing, only text objects.
First, use _AeccMoveTextToElevation to move the text objects to the elevations they display.
Create your surface, then use _AeccAddSurfaceDrawingObjects to add the elevated text objects to the surface. Be sure to set the Object Type to text.
