@nostupidquestions ,
I understand what you are saying now. Thank you for the example photo. I tried to recreate this and with the below results:
- I can attach two pipes to one structure (they come in attached in a "stacked" formation by default), and also drag the pipe ends around demonstrating (at least in plan view) Side-by-Side pipes.
- As soon as I move the structure, the pipes "reconnect" to their specific "connection ports" that for custom structures are set in the Infrastructure Parts Editor. (They revert back to the "stacked" formation)
To this point, while in, the out of the box behavior, it is not presently available using the factory parts catalog. This might be a great opportunity to suggest a "structure" that is readily anticipating multiple pipes in a side by side configuration in the Civil Ideas Page, or to be created using the Infrastructure Parts Editor to create a custom structure to add to the catalog and in turn the workflow.
This is also a great opportunity for you to tell us how you are working around a known limitation of the default catalog structure configuration? While this may be some form of customization and unsupported, it could be valuable to others trying to accomplish the same thing.
Copper Chadwick
Designated Support Specialist
