Civil 3D Forum
Model Space not accessible
8 REPLIES 8
Message 1 of 9
3586 Views, 8 Replies
I have a drawing where I cannot access the model space anymore. As soon as I click on the model tab or type in model, Civil 3D freezes up to a solid black background and no crosshair. I cannot type in any commands.
This happens only on one file, I already tried audit and recover, but had no luck so far.
Can anyone help me with this?
Best,
Marion
Tags (2)
8 REPLIES 8
Message 2 of 9
Jay_B
Try creating a new drawing from your dwt file.
Insert corrupt.dwg into new.dwg at 0,0,0 and explode block (which shares the same name of inserted drawing).
Save new.dwg > any change in accessing model space?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 9
BushW
Hello @Anonymous
Sorry, to hear that you are having this problem. In order to help you, I need to ask you a couple of questions.
  1. What AutoCAD version and product
  2. What Windows version are you using?
  3. Does the file hangs or crashes?
  4. Are you having slow performance when editing and manipulating the file.
  5. Are you getting any error message when opening or when working in the file.
  6. Some commands do not work or have a considerable delay.
  7. Unexplained file size increase.
  8. Display/regen problems.
  9. Drawing elements missing.
Any additional information you can provide along with posting the drawing will greatly help in solving your problem.
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 4 of 9
AllenJessup
If you have any Model Space views set. You could try checking the Select Initial View box on the Open dialog box.
Allen Jessup
CAD Manager - Designer
Message 5 of 9
in reply to: BushW
Hi @BushW
Thank you for your quick reply. Please find answers to your questions below:
  1. What AutoCAD version and product: Civil 3D 2016
  2. What Windows version are you using? Windows 10
  3. Does the file hangs or crashes? Not before this issue came up.
  4. Are you having slow performance when editing and manipulating the file. A little, but I had 3 or 4 drawing files open.
  5. Are you getting any error message when opening or when working in the file. No, I can still open the file normally with any error messages.
  6. Some commands do not work or have a considerable delay. No
  7. Unexplained file size increase. Seems to be reasonable given the content (1,700 KB approx for xref, data shortcuts and some labeling)
  8. Display/regen problems. No
  9. Drawing elements missing. No, in fact I was able to make modifications to some labels through the viewports and print it (even if I could not access the model space anymore). Nothing was missing.
A coworker tried to open the file and he told me that eventually the model space came up, but it took at least an hour. The file is attached.
Best,
Marion
Message 6 of 9
AllenJessup
I opened the drawing in 2017. There was one message about lost sheet association. The drawing loaded quickly and a click on the Model tab brought me immediately to Model Space. The are Model Space opened to was blank, so I only saw a black screen. But a zoom extents let me see the objects in the model.
There are Xrefs that are missing. It's possible there is a problem with one of those. Try unloading the Xrefs before changing to Model Space. If this lets you switch. Try the Recoverall command to recover all the Xrefs. Also. It looks like there may have been Drefs. So recover any drawings containing them.
This is only based on what I've seen in the one drawing. So it's a guess based on that.
Allen Jessup
Message 7 of 9
BushW
in reply to: AllenJessup
Hello @Anonymous
I had the same experience as @AllenJessup in 2016 and 2017. Drawing opened up quickly and I was able to switch to model space tab with no problem.
I also agree that it might be related to the XREF's so, I suggest following @AllenJessup recommendations on doing the Recoverall command to recover all the Xrefs to see if that solves the issue. I hope that help solve your problem.
Please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so and I'm here to help.
Wendell Bush
Message 8 of 9
in reply to: BushW
Thank you @AllenJessup and @BushW!
Once I unloaded the xrefs I was able to access the model space. I reloaded them one at a time and ran a recoverall. Now the file seems to work fine.
Message 9 of 9
cvlci_CAD
Unloading xref's is my go to method of getting files open that are corrupt or fatal erroring.  Normally when someone sends me a path to a file that won't open my first order of business is to copy the file to my local hard drive and disconnect the network drive so the software can't load the xref's.  95% of the time this allows me to open the file.  Then the trick is just figuring out which XREF is the culprit!
Rail Community
