mapiinsert image background transparency setting
kwilktrihydro
Message 1 of 8
kwilktrihydro
First, using the command mapiinsert I bring in the raster UAS image. As you can see below. When I first bring it in the background color of the image is black.
Then I go to the image properties, set the Background Transparency, to “Yes”. Then I change the transparency color to “black”.
Everything works as expected. As you can see below the background is removed from the raster image.
However, if I then save and close the drawing – when I re-open the drawing the background transparency of the image has returned and I again have to go into the image properties to set the back ground transparency color to black.
Is there a system setting that controls this? I don’t remember having this issue in the past and am thinking there must be.
Thank you in advance for any help!
Kelby
Kelby Wilkison, P.E.
Civil Engineer
Trihydro Corporation
Replies (7)
Message 2 of 8
jefflambert9091
We had that happen here. Double check that you have all your updates and then we had to repair. FYI, we are in 2018.
Jeff
Civil 3D 2024
Message 3 of 8
lynn_zhang
Hello @kwilktrihydro ,
Just checking to see if your problem has been solved. Did the response from above help answer your question? Let us know if you still need help.
Lynn Zhang
Message 4 of 8
kwilktrihydro
Hey I got all of my updates installed finally. Sorry it takes out IT awhile to get to updates sometimes.
That being said I still have the problem. However, this may need to get moved to Raster Design. From asking around my work it sounds like this is something that is happening only to those of us that have Autodesk Raster Design installed. I've found a work around using image trim, but I'm still curious if it's a setting somewhere.
Thanks again for your assistance.
Civil Engineer
Message 5 of 8
ChicagoLooper
Check whether 0 or 1.
For ‘ON’ make it like this:
TRANSPARENCYDISPLAY=1.
Chicagolooper
Message 6 of 8
MikeKitchen5860
I have this problem... in 2023! It's a client logo which resets its transparency color back to black every time I reload. I agree, it would be great if all clients used blocks for their logos. But most people love using tiffs, pngs, etc... for reasons. And no, none of the suggestions provided thus far make the problem go away. Hey, @autodesk, has anyone fixed this yet?!
Mike Kitchen
Osprey Engineering Inc.
C3D 2023.2.3
Message 7 of 8
Ultimately
Still a issue in editions 2022, 2023, 2024, and 2025 that I've tested recently.
Message 8 of 8
pendean
Community Legend
Community Legend
@Ultimately wrote: @kwilktrihydro
You yourself(s) (and everyone else that wants it fixed) will need to report it to Autodesk for a resolution
Post here is the ideal way https://forums.autodesk.com/t5/civil-3d-ideas/idb-p/31
If it's not a bug, just a workflow, you yourself(s) will need to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help to confirm:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
HTH
