mapiinsert image background transparency setting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
First, using the command mapiinsert I bring in the raster UAS image. As you can see below. When I first bring it in the background color of the image is black.
Then I go to the image properties, set the Background Transparency, to “Yes”. Then I change the transparency color to “black”.
Everything works as expected. As you can see below the background is removed from the raster image.
However, if I then save and close the drawing – when I re-open the drawing the background transparency of the image has returned and I again have to go into the image properties to set the back ground transparency color to black.
Is there a system setting that controls this? I don’t remember having this issue in the past and am thinking there must be.
Thank you in advance for any help!
Kelby
Civil Engineer
Trihydro Corporation
