level of detail
level of detail
rmkaack-jvb
Message 1 of 14
level of detail
rmkaack-jvb
I am using c3d 2020, did they take away the level of detail button under View/views on the ribbon? I know I can
type the command, but was hoping to find it on the ribbon.
Replies (13)
Message 2 of 14
rkmcswain
I'm hoping you want it to turn it OFF.
Turn that puppy OFF and never, ever turn it on.
Smiley Surprised
It's not in my 2020, or 2019.
You can type in the beginning of the command name in the Application Menu search bar and it will search the entire CUIX file.
Message 3 of 14
neilyj666
Add it to acaddoc.lsp and never be troubled again....!!!!!!
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 14
samir_rezk
The command is no longer accessible through the ribbon. You must type it in!
I am curious to know why @rkmcswain recommends turning it off? I personally like it on!
Samir Rezk
Technical Support Specialist
Message 5 of 14
rkmcswain
@samir_rezk  - for one reason, when it's enabled and you have multiple drawings open, on many occasions command line input from one drawing is directed to a background drawing. If a user is not experienced with this bug, it appears as if C3D is locked up, or at least not accepting keyboard input.
Read more: [1] [2] [3] [4]
Message 6 of 14
neilyj666
You can of course add it to the ribbon via the CUI should you wish
Message 7 of 14
AllenJessup
I wouldn't go so far as to say never turn it on. But it's better left off in most cases. The only time I use it is when I have very large surfaces created from our county wide Lidar.
BTW. That's one of the variables I track with the Sysvarmonitor.
Allen Jessup
CAD Manager - Designer
Message 8 of 14
rkmcswain
@AllenJessup  - how are you watching that with the sysvarmonitor? There is no system variable for that, right?
Message 9 of 14
AllenJessup
My mistake. When I did a Levelofdetailoff from the command line. I got a message "**** System Variable Changed ****
1 of the monitored system variables has changed from the preferred value. Use SYSVARMONITOR command to view changes". So I thought, "Oh. It's being monitored". But that was about a variable that was being monitored. Not Level of detail.
What I do have is (command "LEVELOFDETAILOFF") in my acaddoc.lsp file.
Allen Jessup
Message 10 of 14
RyanR-ISS
THANK YOU THANK YOU THANK YOU . . .
You have resolved an issue several of us here have had, but apparently were content to deal with - the wandering active command lines, and having to open others dwgs to see which one received the keystrokes.  Just so happens that I was looking up the level of detail setting and it was mentioned.
This one was right up there with the annotative hatches apparently causing the never-ending undo button clicking to go back just a few operations.  I think it was an AllenJessup post for that one, years ago.  Thanks to you both!
Message 11 of 14
brian.strandberg
I think everything has been explained very well, but I want to add 2 things.
1. If you are looking for if something is in the ribbon, there is a search bar in the application menu.  See video below (10 seconds).
2. I have seen weird issues printing surfaces with Level of Detail on.  That is why I turn the sucker off when CAD launches.  If I batch plot items and don't have that in the startup, I could see that weird issue printing.  Its been a while since I have seen that issue, so generally happy to keep it off.
If anyone knows a way to pre-emptively prevent the level of detail warning popup from showing let me know.  I train our people to click 'don't show again' but I would love to prevent the popup in the first place.
(view in My Videos)
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 12 of 14
sandi.biester
It's under the "Viewport tools" dropdown
Message 13 of 14
neilyj666
As a follow up to this very old thread, the Level Of Detail functionality in Civil 3D 2025 is much improved and can be controlled per surface (if desired) and is available via right click, Prospector or Ribbon
Message 14 of 14
BlackBox_
FWIW - I recently changed employers and my new shop is still using C3D 2022, where this is very much still an issue.
So, I developed a solution where PREVIEW Command is Veto()-ed, LEVELOFDETAILOFF Command is invoked, PREVIEW Command then re-invoked, and when complete, LEVELOFDETAIL Command is invoked turning it back on... this appears to be unnoticeable (once you turn off the disable/enable dialogs) and precludes the command line entry from going to an inactive document, allowing the benefit of using LevelOfDetail while working.
I just used Autoloader to include a custom LEVELOFDETAILMODE system variable, and so far, it works great.
I've already found that I also want OBJECTVIEWER accounted for, so there may be other Commands not mentioned here that would benefit, in kind.
With this issue only applying to legacy versions (fixed in new versions), just reach out if you'd like help with the code described above.
Cheers
"How we think determines what we do, and what we do determines what we get."
Chris (BlackBox) Bradley
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
