FWIW - I recently changed employers and my new shop is still using C3D 2022, where this is very much still an issue.
So, I developed a solution where PREVIEW Command is Veto()-ed, LEVELOFDETAILOFF Command is invoked, PREVIEW Command then re-invoked, and when complete, LEVELOFDETAIL Command is invoked turning it back on... this appears to be unnoticeable (once you turn off the disable/enable dialogs) and precludes the command line entry from going to an inactive document, allowing the benefit of using LevelOfDetail while working.
I just used Autoloader to include a custom LEVELOFDETAILMODE system variable, and so far, it works great.
I've already found that I also want OBJECTVIEWER accounted for, so there may be other Commands not mentioned here that would benefit, in kind.
With this issue only applying to legacy versions (fixed in new versions), just reach out if you'd like help with the code described above.
Cheers
"How we think determines what we do, and what we do determines what we get."
