I am trying to bring a KMZ file from Google Earth into AutoCAD. I can convert the KMZ to a shapefile through a seperate program, the problem I am having is that AutoCAD doesn't seem to recognize the coordinate system and convert it correctly to the state plan coordinate system I am working in. I am not opposed to utilizing a different coordinate system in my drawing, all I really need is to be able to bring in background Bing aerials. What coordinate system is best suited for interfacing with Google Earth? I would like to be able to export to KMZ/KML in the future as well.
Solved by Pointdump. Go to Solution.
It seemed to be an issue with the fact that Google earth is in degrees and the drawing only wants to use units of feet or meters. Even if I set my coordinate system to one based on degrees, when I try to bring in a Bing aerial it want to know whether my dwg is in feet or meters.
Kristen,
Please post your KMZ file or the Shapefile. (Zip up all 4 files -- DBF, PRJ, SHP, and SHX)
What is the desired Coordinate System?
Dave
Dave Stoll
Las Vegas, Nevada
Here is the shapefile info in zip file. I cannot post the kmz as is it does not ahve a valid extension for attachment per the website.
Kristen
Kristen,
You can post any file format on the forum if you put it in a zipped folder.
So what coordinate system did you want this shapefile in?
Dave
Dave Stoll
Las Vegas, Nevada
Kristen,
OK, so these points are in Warner Robins, next to the Robins Air Force Base? Drawing attached, GA83-WF (US Survey Feet)
Dave
Dave Stoll
Las Vegas, Nevada
Kristen,
So, in answer to your questions.
Open the PRJ file with Notepad and you'll see this:
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
The "GCS" stands for Geographic Coordinate System (Round Earth with Angular Coordinates). Bing Live Maps only works with Projected Coordinate Systems (Flat with Cartesian Coordinates).
When you're ready to export a KML, you can do that in the Toolbox Tab under Miscellaneous Utilities.
Dave
Dave Stoll
Las Vegas, Nevada
Thanks Pointdump. So I am guessing that you converted the points from Lat/Long to State Plane before bringing them into CAD. I have been doing that for a few years, but I was trying to find a more direct route as I expect to have to do this many, many, many times over the coming month. Looks like I am out of luck as Bing Maps only works with projected coordinate systems. That is why my decimal degree points all fall within 1 foot on the state plane based map. I wanted to find out if I set the shapefile up with the correct coordinate system initially, if CAD could convert it correctly to my State Plane drawing when it comes in. I convert from state plane to lat/long and vice versa in the Earthpoint service by Google frequently - and I guess I will have to keep on.
Kristen,
I used MAPIMPORT to bring that Shapefile directly into a GA83-WF drawing.
As for the KMZ, I'd do like you did, convert it to a shapefile first. I don't know if Civil 3D can directly import a KMZ/L.
Here's a really excellent 34-minute video by Jason Porter on how to transform data like a boss.
https://www.youtube.com/watch?v=g7HW6apnh3g
Dave
Dave Stoll
Las Vegas, Nevada
Kristen,
I made a ScreenCast of how to change the Coordinate System of the Shapefile on-the-fly with MapImport. One thing to make note of is to change the units to US Survey Feet BEFORE you select your GA83-WF Coordinate System. If you don't do that, C3D will lie to you and tell you your units are Survey Feet when in fact they are International Feet. With State Plane Coords that could throw things off.
Dave Stoll
Las Vegas, Nevada
Really. That what I was trying to do without any luck. I tried bringing the points into a drawing that was set up on state plane coords with no luck (tried with and without the Bing maps already in background) I also tried bringing the points into a new drawing and then setting the drawing up to state plane. No luck there either. However I have been utilizing the "Connect" tools through the Planning and Analysis toolspace to bring in the shapefile. I will take a look at this and see if mapimport makes a difference. I thought it was because AutoCAD wasn't able to recognize the coordinate system of the shapefile, so it didn't project it correctly - but it seems that you have had no trouble bringing it in directly.
As far as bringing in a KMZ/L file directly - I have done some searching on the forum, but no luck. It is quite easy to change to a shapefile, so I will keep working it that way.
Let me take a look over the videos you sent and see what I can come up with. Thanks so much!
Kristen,
Please post the "Green Route" Shapefile.
Dave
Dave Stoll
Las Vegas, Nevada
Here it is. I included the original .csv file as well. I converted this to a shapefile utilizing a free program called Quantum GIS.
Kristen,
This is weird. Never had this happen before with zipped files. I can't use any of the files in Final Green. Could you please send them again?
Dave
Dave Stoll
Las Vegas, Nevada
HI:
First of all, thank you very much to all for your help. In the steps that are shown in the video is possible to import shapefiles but no .kmz. How is possible to insert these .kmz in my CAD file?
Thanks in advance
Rafael Moreno
If you were to consider low cost third party software, DotSoft's GeoLocation Plus will import KML/KMZ files directly into any AutoCAD 2015 or higher product. It also does a lot of other things to improve your productivity !
