Hi, I got a problem with my corridor surface, somehow it looks jagged...I never had such a problem. Here are two pictures of the surface and the assemblies, the profile is just made out of straight lines.
Have you checked what profile your Vertical Baseline is set to? Has is been set to your existing ground by any chance?
Corridor Properties -> Parameter tab
No, I found out it has something to do with the sub-base (the lower lane). For example if I delete the lower lane on the upper assembly in the picture, the corridor surface looks fine. My Problem is on the second assembly the left subassembly with the ditch is a default one where I can't just delete the lower lane...
